[GRASS-dev] [GRASS GIS] #2140: m.proj does not handle cs2cs failure
GRASS GIS trac at osgeo.org
Sun Mar 20 20:52:24 PDT 2016
  Reporter:  wenzeslaus          |      Owner:  grass-dev@…
      Type:  defect              |     Status:  new
  Priority:  normal              |  Milestone:  7.0.0
 Component:  Projections/Datums  |    Version:  svn-trunk
Resolution:                      |   Keywords:  m.proj, cs2cs
       CPU:  All                 |   Platform:  All
Comment (by jrobparsons):
 Sent patch to Vaclav Petras.
 1. PEP8 compliant except for 2 GUI parser  'description'  lines.
 rp at concepts:~/grass7_trunk/scripts/m.proj$ pep8 m.proj.py
 m.proj.py:28:80: E501 line too long (85 > 79 characters)
 m.proj.py:78:80: E501 line too long (97 > 79 characters)
 2. Replaced tabs with spaces.
 indents are on 4 space boundaries.
 3. Added test for the presence of '+' in proj_in and proj_out strings.
     if proj_in:
         if '+' in proj_in:
             in_proj = proj_in
         else:
             grass.fatal(_("Invalid PROJ.4 input specification"))
 4. Removed this comment inserted by previous programmer.
     # FIXME: input_x,y needs to split on multiple whitespace between them
 This appears to not be a problem.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2140#comment:7>
