[GRASS-dev] [GRASS GIS] #1994: wxPy loc'n wiz: WKT doesn't ask for datum transform terms
GRASS GIS trac at osgeo.org
Thu Mar 24 10:55:33 PDT 2016
  Reporter:  hamish              |      Owner:  grass-dev@…
      Type:  defect              |     Status:  closed
  Priority:  normal              |  Milestone:  7.0.4
 Component:  Projections/Datums  |    Version:  svn-releasebranch70
Resolution:  fixed               |   Keywords:  location wizard, g.proj
       CPU:  All                 |   Platform:  All
Changes (by neteler):
 * status:  new => closed
 * version:  svn-trunk => svn-releasebranch70
 * resolution:   => fixed
 * milestone:  6.4.4 => 7.0.4
Comment:
 Solved in trunk and relbranch70:
 Example:
 g.proj wkt=~/tmp/brazil.prj datumtrans=-1 -w
 1
 Used in whole sam69 region
 towgs84=-57.000,1.000,-41.000
 Default 3-Parameter Transformation (May not be optimum for older datums;
 use this only if no more appropriate options are available.)
 2
 Used in Brazil
 towgs84=-60.0,-2.0,-41.0
 3
 Used in South America?
 towgs84=-77.0,3.0,-45.0
 Old GRASS sam69 parameters
 Closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1994#comment:1>
