[GRASS-dev] [GRASS-SVN] r68140 - in grass/trunk/scripts: d.correlate d.frame d.polar d.rast.edit d.rast.leg d.redraw db.dropcolumn db.in.ogr db.out.ogr db.test db.univar g.extension g.extension/testsuite g.extension.all g.manual g.search.modules g.search.modules/testsuite i.colors.enhance i.image.mosaic i.in.spotvgt i.oif i.spectral i.tasscap m.proj r.blend r.buffer.lowmem r.colors.stddev r.fillnulls r.grow r.import r.in.aster r.in.srtm r.in.wms r.mask r.out.xyz r.pack r.plane r.reclass.area r.shade r.tileset r.unpack r3.in.xyz v.build.all v.centroids v.db.addcolumn v.db.addtable v.db.dropcolumn v.db.droprow v.db.droptable v.db.join v.db.reconnect.all v.db.renamecolumn v.db.univar v.db.update v.dissolve v.import v.in.e00 v.in.geonames v.in.lines v.in.mapgen v.in.wfs v.krige v.pack v.rast.stats v.rast.stats/testsuite v.report v.unpack v.what.strds v.what.strds/testsuite wxpyimgview
Markus Neteler neteler at osgeo.org
Wed Mar 30 07:26:37 PDT 2016
On Fri, Mar 25, 2016 at 8:56 AM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2016-03-25 8:54 GMT+01:00 Pietro <peter.zamb at gmail.com>:
>> Indeed there were no discussion, feel free to revert.
>> I'm still confused... when can I break the trunk branch? :-)
Trunk may be broken according to our rules.
And Pietro's contributions are usually outstanding, so I am not quite scared! :)
> personally I would wait with such changes to the moment when we will
> create releasebranch_7_2 (two months before planning 7.2. release. For
> now I would suggest to revert these changes from trunk. Any opinion?
Well, trunk is yet trunk and we did not freeze anything.
The Python3 compatibility is quite important and a PITA to introduce a
week after creating the 7.2. branch ;)
Well, now Pietro already reverted it but IMHO it is a important improvement.
Do also the other devs want to wait with this change? I am a bit
afraid that may get lost on the way.
Markus
