[GRASS-dev] Seeking advices for image segmentation algorithms and windows compile question
Maris Nartiss maris.gis at gmail.com
Wed May 4 23:39:04 PDT 2016
I would strongly suggest to set up a dual boot on your system with
Ubuntu or Debian as a development platform. You will save tons of time
wasted on fighting with Windows'isms. Don't waste your time on
virtualisation unless you can give VM two cores + 8Gb RAM. No,
developing GRASS GIS doesn't need so much resources but full
virtualisation does (to be reasonable fast). Yes, it will take a day
or two to get dualboot up and running but will pay back (by time)
really fast.
Save yours (and our) time!
Māris.
2016-05-05 2:19 GMT+03:00 Yang, Bo (yangb2) <yangb2 at mail.uc.edu>:
> Hello,
> In addition, is there anyone who use win10 OS to compile the GRASS? I have
> compiled GRASS in window 10 64bit system followed the tutorial [1]. In last
> step of the tutorial it mentioned:
>                 >Usage:
>                 >To start GRASS use the icon on the desktop or if you want
> to be able to use the command line from within GRASS.
>                 >Type in cmd console (assuming that we compiled GRASS 7.1):
>                 >c:\osgeo4w\bin\grass71svn.bat
> However, No matter I use CMD console or the OSGeo4W Shell. I got the same
> error below:
>                 '""' is not recognized as an internal or external command,
> operable program or batch file.
> From the error.log there is no error during the compiling. There is no error
> reported in former steps either, and I can see the file " grass71svn.bat "
> is located in the right place. But I still can't start the compiled GRASS. I
> Googled this error but can't find helpful information. Any suggestion would
> be greatly appreciate.
> P.S. scripts in grass71svn.bat:
> @echo off
> rem
> rem #
> rem # GRASS initialization bat script (OSGeo4W)
> rem #
> rem
> SET OSGEO4W_ROOT=@osgeo4w@
> rem
> rem Set environmental variables
> rem
> call %OSGEO4W_ROOT%\bin\o4w_env.bat
> call %OSGEO4W_ROOT%\apps\grass\grass-7.1.svn\etc\env.bat
> rem
> rem Launch GRASS GIS
> rem
> "%GRASS_PYTHON%" "%GISBASE%\etc\grass71.py" %*
> rem
> rem Pause on error
> rem
> if %ERRORLEVEL% GEQ 1 pause
> [0] https://wiki.osgeo.org/wiki/GRASS_GSoC_2016_Segment_Algorithms
> [1] https://trac.osgeo.org/grass/wiki/CompileOnWindows
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
