[GRASS-dev] [SoC]Week-1 WebGrass
Rashad Kanavath mohammedrashadkm at gmail.com
Mon May 30 05:06:49 PDT 2016
On Mon, May 30, 2016 at 1:56 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> On 30 May 2016 at 13:36, Rashad Kanavath <mohammedrashadkm at gmail.com>
> wrote:
> > Hello Luca,
> Hi,
> > Thanks for testing.
> > On Mon, May 30, 2016 at 12:14 PM, Luca Delucchi <lucadeluge at gmail.com>
> > wrote:
> >> On 30 May 2016 at 11:09, Mayank Agrawal <mayankagrawal333 at gmail.com>
> >> wrote:
> >> > Readme-
> >> > in the webgrass folder https://github.com/rashadkm/webgrass
> >> > mkdir build
> >> > cd build
> >> > cmake ..
> >> > make
> >> > sudo ./wgrass.wt --http-address=0.0.0.0 --http-port=8080 --docroot ../
> >> I read it already, but it was not enough
> >> > These are the dependencies which will be required beforehand. Install
> >> > them one by one.
> >> > libwt-dev - C++ library and application server for web applications
> >> > [development]
> >> > libwtdbo-dev - Wt::Dbo ORM library for Wt [development]
> >> > libwtdbofirebird-dev - Firebird backend for Wt::Dbo [development]
> >> > libwtdbomysql-dev - MySQL/MariaDB backend for Wt::Dbo [development]
> >> > libwtdbopostgres-dev - PostgreSQL backend for Wt::Dbo [development]
> >> > libwtdbosqlite-dev - sqlite3 backend for Wt::Dbo [development]
> >> > libwtext-dev - additional widgets for Wt, based on ExtJS 2.0.x
> >> > [development]
> >> > libwtfcgi-dev - FastCGI connector library for Wt [development]
> >> > libwthttp-dev - HTTP(S) connector library for Wt [development]
> >> > libwttest-dev - test connector library for Wt [development]
> >> > libpugixml-dev
> >> please add this in the readme file
> >> > After this, do let me know with the error.
> >> no error, now I'm able to run it but I cannot modify the grassdata
> >> directory, is it normal?
> > Yes and No!
> > Yes it is expected that there is not user specific location-mapset upload
> > ready now.
> you could set by default $HOME/grassdata (it is quite common to have a
> grassdata in our own $HOME)
I think the cmake variable GRASS_DATA_DIR can be set to $HOME/grassdata.
and during
configure check if it is a valid dataset.
> > I will push a cmake configuration that downloads sample grass7 dataset.
> So
> > you can test it easily.
> no please, no download sample dataset, should be better to set our
> grassdata in a cmake variable
using sample data is not for everyone. This is a cmake option which is OFF
by default.
> ciao
> Luca
> www.lucadelu.org
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160530/d8866c47/attachment.html>
