[GRASS-dev] [GRASS GIS] #3153: g.gui.animation freezes when trying to add decorations
GRASS GIS trac at osgeo.org
Mon Nov 14 01:22:12 PST 2016
  Reporter:  veroandreo   |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.2.0
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:  g.gui.animation
       CPU:  Unspecified  |   Platform:  Linux
Comment (by veroandreo):
 I have tested both in trunk r69822 and 72 release branch r69821 and the
 issue prevails. Steps to reproduce are:
 1. call g.gui.animation from terminal
 2. add new animation
 3. add stvds -> ok -> ok (animation works fine)
 4. go to export icon
 5. set a file type and name
 6. go to decorations tab
 7. add text
 8. click export from there... No way, it does not respond. It is frozen.
 The only remaining option is to close.
 If you try to export directly, without touching the decoration tab, it
 works fine. However you don't get any decoration.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3153#comment:12>
