[GRASS-dev] t.rast.out.xyz not exporting all cells in the computational region
Veronica Andreo veroandreo at gmail.com
Wed Nov 30 05:10:58 PST 2016
Hello devs,
AFAIU, to activate the NULL export in r.out.xyz is then a trivial change,
but we do not know which letter to use as flag because -n is already used
to indicate the opposite behaviour (?). Is it too difficult to change
default behaviour to export NULL values and keep then, the -n flag as in
r.stats to not export/report NULL values?
I'm asking from ignorance, I would not know how to implement that myself.
Sorry for bothersome... and thanks much!!
Best,
Vero
2016-11-30 11:19 GMT+01:00 Markus Neteler <neteler at osgeo.org>:
> On Tue, Nov 29, 2016 at 3:38 PM, Luca Delucchi <lucadeluge at gmail.com>
> wrote:
> > I propose to add a flag to r.out.xyz to permit to export also null
> > values, what do other devs think?
> Since it is a trivial change in r.out.xyz.py (conditionalize the r.stats'
> flag
>   -n   Do not report no data value
> I would suggest to add a flag to optionally allow no data export (the
> respective note in the manual page to be modified then).
> The question is which flag letter to take here (keeing this in mind:
> https://trac.osgeo.org/grass/wiki/MessageStandardization#
> Parametersandflags
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161130/46524248/attachment.html>
