[GRASS-dev] Upcoming 7.2.0: review which addons to move to core
Helmut Kudrnovsky hellik at web.de
Tue Oct 4 07:55:57 PDT 2016
Martin Landa wrote
> Hi Markus,
> 2016-10-04 16:13 GMT+02:00 Markus Metz <
> markus.metz.giswork@
>> My guess for the r.stream.* modules is at least 40 man hours of
>> testing to make sure they work correctly. That includes evaluation of
>> float usage, handling of NULL data, comparison of results with and
>> without the -m flag. Testing should be done with both high-res (LIDAR)
>> and low-res (e.g. SRTM) DEMs.
> about r.stream modules, ASAIR the major blocker for these modules to
> be moved to core is problem is memory mode, right? I don't remember if
> there is any ticket about that. Martin
at least as a comment in this ticket:
https://trac.osgeo.org/grass/ticket/2237#comment:1
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upcoming-7-2-0-review-which-addons-to-move-to-core-tp5274533p5289237.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
