[GRASS-dev] [GRASS GIS] #3187: Attribute table manager refreshing when connecting a distant sqlite database
GRASS GIS trac at osgeo.org
Wed Oct 19 07:22:30 PDT 2016
database
 Reporter:  vincent         |      Owner:  grass-dev@…
     Type:  defect          |     Status:  new
 Priority:  minor           |  Milestone:  7.0.6
Component:  wxGUI           |    Version:  svn-trunk
 Keywords:  database,layer  |        CPU:  Unspecified
 Platform:  Linux           |
 Given a vector map without layer, you may want to make a connection with
 an external database sqlite file. Doing this with the wxgui attribute
 table manager, when specifying the path for an existing sqlite file,
 'Table' and 'Key column' dropdown lists are not immediately refreshed, so
 it is not possible to set properly the new layer. Update only happens if
 you select another entry in the 'Driver' dropdown list (e.g. 'pg'), then
 set it back to 'sqlite'.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3187>
