[GRASS-dev] [GRASS-user] v.rast.stats ERROR
Anna Petrášová kratochanna at gmail.com
Thu Oct 20 17:53:51 PDT 2016
On Thu, Oct 20, 2016 at 4:11 PM, Markus Neteler <neteler at osgeo.org> wrote:
> (moved to GRASS-dev)
> Topic: v.rast.stats error message
> On Fri, Oct 14, 2016 at 8:35 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
>>>ERROR: Unable to add column <1_average DOUBLE PRECISION>.
>>>ERROR: Adding columns failed. Exiting.
>> AFAIR in SQL column names starting with a number isn't allowed.
> Is there any Python wrapper around Vect_legal_filename() which could
> be used here to generate a better error message?
There is only wrapper for G_legal_filename I know of. It would have to
be added. Maybe worth a ticket?
Anna
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
