[GRASS-dev] [GRASS GIS] #3184: v.vect.stats: errors in counts and statistics
GRASS GIS trac at osgeo.org
Tue Oct 25 12:11:03 PDT 2016
  Reporter:  veroandreo  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  closed
  Priority:  normal      |  Milestone:  7.2.0
 Component:  Vector      |    Version:  svn-trunk
Resolution:  fixed       |   Keywords:  v.vect.stats
       CPU:  x86-64      |   Platform:  Linux
Comment (by mmetz):
 In [changeset:"69723" 69723]:
 #!CommitTicketReference repository="" revision="69723"
 v.vect.stats: fix #3184, also remove the erroneous 'half' parameter
 (backport from trunk r69722)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3184#comment:17>
