[GRASS-dev] Passed: GRASS-GIS/grass-ci#1514 (master - 7af1e1c)
Travis CI builds at travis-ci.org
Sat Sep 3 11:15:31 PDT 2016
Build Update for GRASS-GIS/grass-ci
Build: #1514
Status: Passed
Duration: 8 minutes and 36 seconds
Commit: 7af1e1c (master)
Author: Václav Petráš
Message: wxGUI/forms: simply fail when GISBASE is not set
The subsequent imports will likely fail anyway.
Moreover, the code was not actually working (there is
no sys.write) and global variable gisbase was unused.
Also call set_gui_path() function only when needed
(i.e. not when running as part of main GUI).
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@69360 15284696-431f-4ddb-bdfa-cd5b030d7da7
View the changeset: https://github.com/GRASS-GIS/grass-ci/compare/f67fd31a84d2...7af1e1c9b38c
View the full build log and details: https://travis-ci.org/GRASS-GIS/grass-ci/builds/157340703
You can configure recipients for build notifications in your .travis.yml file. See https://docs.travis-ci.com/user/notifications
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160903/15689e98/attachment.html>
