[GRASS-dev] Temporary 3D raster or delete 3D raster in C
Vaclav Petras wenzeslaus at gmail.com
Sun Sep 4 19:08:23 PDT 2016
Hi all,
in r3.in.lidar I want to use temporary 3D rasters. There might be ways to
avoid the need for it, but 3D raster is just the easiest thing for me.
What I need is to delete the temporary raster after I finish the
processing. Ideally I would call something like "close and remove" so that
no more things are written, just deleted. However, I would be fine also
with just writing it using Rast3d_close() and then removing it.
Do you have some suggestions how to solve this?
Thanks,
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160904/982d8c79/attachment.html>
