[GRASS-dev] How to: if undefined, set to NULL?
Nikos Alexandris nik at nikosalexandris.net
Mon Sep 5 06:52:05 PDT 2016
Nikos Alexandris:
>> > Updated in sandbox, see: https://trac.osgeo.org/grass/changeset/69365
>> > Is it though correct?
Vaclav Petras wrote:
>> I was not looking at the logic but
>> if (hue == -1.0) {
>> is not safe. Although it will probably work most of the time if you set it
>> to the exactly same value (`hue = -1;`),
Glynn Clements <glynn at gclements.plus.com> [2016-09-05 16:46:31 +0100]:
>There's no "probably" about it. If you execute "hue = -1;", a
>subsequent "if (hue == -1)" comparison *will* succeed.
>Rounding error only occurs when the correct result isn't exactly
>representable, which isn't the case here. It doesn't occur randomly.
If using -1 is good, it seems simpler (to me, the ignorant) than trying
introducing yet another boolean flag.
Nikos
