[GRASS-dev] [GRASS GIS] #2902: i.segment.hierarchical: Execution of subprocesses was not successful
Markus Neteler neteler at osgeo.org
Wed Sep 7 03:07:24 PDT 2016
successful
>  Setting this to True led me to a
>  bug in pygrass which still had a call to type='rast' instead of
>  type='raster'. Corrected in trunk in r69392.
There appear to be some more to be fixed but I cannot say which ones
are false positives in this sloppy grep search (sorry for the HTML
formatting to preserve line breaks):
find . -type f | xargs grep "'rast'" | grep -v svn/pristine
./scripts/r.shade/r.shade.py:                      type='rast', name=maps)
./scripts/r.grow/r.grow.py:                              type='rast',
name=map)
./gui/wxpython/psmap/dialogs.py:            {'rast': self.currRaster,
'type': rasterType})
./gui/wxpython/psmap/dialogs.py:            {'rast': currRaster, 'type':
str(rasterType)})
./gui/wxpython/lmgr/layertree.py:            module = 'rast'
./lib/python/gunittest/gutils.py:    if type == 'rast' or  type == 'raster':
./lib/python/pygrass/raster/abstract.py:        utils.remove(self.name,
'rast')
./lib/python/pygrass/raster/abstract.py:            utils.rename(self.name,
newname, 'rast')
./lib/python/pygrass/modules/grid/grid.py:                 for r in
findmaps('rast', location=dst[1], gisdbase=dst[2])]
./lib/python/pygrass/modules/interface/testsuite/test_parameter.py:
param = Parameter(diz=dict(name='rast', required='yes',
./lib/python/temporal/temporal_algebra.py:              maptype='rast',
mapclass=RasterDataset,
./lib/python/script/core.py:    if element == 'raster' or element == 'rast':
find . -type f | xargs grep "'vect'" | grep -v svn/pristine
./scripts/v.db.reconnect.all/v.db.reconnect.all.py:    vectors =
gscript.list_grouped('vect')[mapset]
./scripts/v.build.all/v.build.all.py:    vectors =
grass.list_grouped('vect')[mapset]
./gui/wxpython/lmgr/layertree.py:            module = 'vect'
./lib/python/gunittest/gutils.py:    elif type == 'vect':
./lib/python/pygrass/utils.py:    >>> remove('test_vect_2','vect')
./lib/python/pygrass/vector/table.py:        >>>
copy(test_vector_name,'mycensus','vect')
./lib/python/pygrass/vector/table.py:        >>> remove('mycensus', 'vect')
./lib/python/pygrass/vector/table.py:        >>> remove('mycensus','vect')
./lib/python/pygrass/vector/abstract.py:                utils.rename(
self.name, newname, 'vect')
./lib/python/pygrass/vector/abstract.py:        utils.remove(self.name,
'vect')
./lib/python/pygrass/vector/__init__.py:        >>>
copy(test_vector_name,'mytest_vect','vect')
./lib/python/pygrass/vector/__init__.py:        >>> remove('mytest_vect',
'vect')
./lib/python/script/core.py:    >>> list_grouped('vect',
pattern='*roads*')['PERMANENT']
./lib/python/script/db.py:    vects = list_strings('vect')
... anyone willing to go through and fix the few true Python issues?
Those should then also be backported to 7.2.svn.
thanks
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160907/b9629b1f/attachment.html>
