[GRASS-dev] [GRASS GIS] #3145: v.unpack: too sensitive to difference of names in projections
GRASS GIS trac at osgeo.org
Thu Sep 8 01:55:47 PDT 2016
 Reporter:  mlennert             |      Owner:  grass-dev@…
     Type:  enhancement          |     Status:  new
 Priority:  normal               |  Milestone:  7.2.1
Component:  Vector               |    Version:  svn-trunk
 Keywords:  v.unpack projection  |        CPU:  Unspecified
 Platform:  Unspecified          |
 Trying to use v.unpack I got the following error:
 ATTENTION: Difference between PROJ_INFO file of packed map and of current
            - name: Belge 1972 / Belgian Lambert 72
            + name: Lambert Conformal Conic
            + proj: lcc
            datum: bel72
            ellps: international
            - proj: lcc
            lat_1: 51.16666723333333
            lat_2: 49.8333339
            lat_0: 90
            lon_0: 4.367486666666666
            x_0: 150000.013
            y_0: 5400088.438
            no_defs: defined
 AFAIU, the difference in position of "proj: lcc" is not the problem, it is
 only the difference in projection names. Maybe v.unpack could/should
 ignore a difference of names if all the other parameters are the same ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3145>
