[GRASS-dev] [GRASS GIS] #3145: v.unpack: too sensitive to difference of names in projections
GRASS GIS trac at osgeo.org
Thu Sep 8 07:13:47 PDT 2016
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.2.1
 Component:  Vector       |    Version:  svn-trunk
Resolution:               |   Keywords:  v.unpack projection
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:1 neteler]:
 > Can you please attach the PROJ_INFO file? And, if known, the EPSG code?
 Sure, but I think the issue is a generic one, not specifically linked to
 this case.
 The PROJ_INFO of the .pack file corresponds to EPSG31370:
 name: Belge 1972 / Belgian Lambert 72
 datum: bel72
 ellps: international
 proj: lcc
 lat_1: 51.16666723333333
 lat_2: 49.8333339
 lat_0: 90
 lon_0: 4.367486666666666
 x_0: 150000.013
 y_0: 5400088.438
 no_defs: defined
 And here's the PROJ_INFO file of the location:
 name: Lambert Conformal Conic
 proj: lcc
 datum: bel72
 lat_2: 49.8333339
 lat_0: 90
 x_0: 150000.013
 y_0: 5400088.438
 no_defs: defined
 I don't remember how this location was created (based on a file, perhaps),
 but as you can see the parameters are strictly identical, it's just the
 name that differs.
 v.unpack uses compare_key_value_text_files from lib/python/script/core.py.
 Maybe a solution would be to add to that function a list of keys to skip
 and then v.unpack could add 'name' as a key to skip. Thus, if all other
 parameters are equal the projection test wouldn't fail.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3145#comment:2>
