[GRASS-dev] broken winGRASS
Helmut Kudrnovsky hellik at web.de
Thu Sep 8 22:22:30 PDT 2016
Helmut Kudrnovsky wrote
> hi,
> it seems  the daily winGRASS (standalone and OSGeo4W) are broken:
> see
> https://wingrass.fsv.cvut.cz/grass73/x86_64/logs/log-r69289-73/error.log
> GRASS GIS 7.3.svn r69289 compilation log
> Started compilation: Mon Aug 29 03:54:24     2016
> Errors in:
> /c/msys64/usr/src/grass_trunk/raster/r.in.lidar
> /c/msys64/usr/src/grass_trunk/raster3d/r3.in.lidar
> /c/msys64/usr/src/grass_trunk/vector/v.out.lidar
> /c/msys64/usr/src/grass_trunk/vector/v.in.lidar
> In case of errors please change into the directory with error and run
> 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> Finished compilation: Mon Aug 29 04:18:03     2016
winGRASS seems to be still broken.
the last 7.2/7.3 64bit error log is from end of August (see above and
https://wingrass.fsv.cvut.cz/grass73/x86_64/logs/log-r69289-73/error.log)
there is neither 32bit/64bit standalone 7.2/7.3 nor osgeo4w winGRASS
binaries available in the last days.
Any ideas?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/broken-winGRASS-tp5283441p5284887.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
