[GRASS-dev] [GRASS GIS] #3149: Adding database information to v.info metadata output
GRASS GIS trac at osgeo.org
Sun Sep 11 03:39:09 PDT 2016
  Reporter:  huhabla      |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.2.0
 Component:  Default      |    Version:  svn-releasebranch72
Resolution:               |   Keywords:  vector, info, v.info
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by huhabla):
 Replying to [comment:4 mlennert]:
 > Replying to [comment:3 huhabla]:
 > > Replying to [comment:2 mlennert]:
 > > > Why do you need this in v.info and what's wrong with v.db.connect -p
 > > Why is this information not present in v.info? Why do we need a second
 command to get this information about a vector map?
 > Because it's module that manages that setting that provides the info, as
 with other modules (e.g. v.category).
 Exactly, it manages the database connection and should also display the
 connection parameter.
 > >The output of v.db.connect -g is not well
 > >designed for parsing, neither for bash
 > >nor for the python-grass-script library.
 > Then let us improve that :-)
 I guess there was a specific reason behind the implementation of the "-g"
 flag in v.db.connect in the way it is. I fear to break existing
 functionality when modifying v.db.connect "-g" flag output.
 Since we do not have enough module tests, it would be hard to figure out
 what will break in existing modules, in examples and documented work flows
 and even more harder to figure out if extensions will break.
 > Just to be clear: this is not a -1 to your idea. I just want to make
 sure we think about it. In general, I'm wary of introducing the same
 functionality in two different modules. IMHO, it creates the risk of
 feature bloat and of confusion for the users.
 IMHO the database connection is vector map metadata that should be
 available within v.info, so the user does not have to search for another
 module to get this information. The default settings of vector layer
 database management usually does not require the user to use v.db.connect,
 hence its capabilities is mostly unknown to the user.
 I think the less invasive solution is to modify v.info, especially since i
 have already implemented 6 tests to verify the functionality. ;)
 BTW, v.info is an integral part of the gunittest validation approach,
 hence the more metadata information about a vector map is available via
 v.info, the easier it is to implement tests.
Ticket URL: <http://trac.osgeo.org/grass/ticket/3149#comment:5>
