[GRASS-dev] [GRASS GIS] #774: i.rgb.his, i.his.rgb, d.his support for >8 bit
GRASS GIS trac at osgeo.org
Mon Sep 12 07:16:12 PDT 2016
  Reporter:  hamish       |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.4.0
 Component:  Raster       |    Version:  svn-develbranch6
Resolution:               |   Keywords:  i.rgb.his, i.his.rgb, d.his
       CPU:  All          |   Platform:  All
Comment (by nikosa):
 Modified versions for i.rgb.his and i.his.rgb in respective directories at
 https://trac.osgeo.org/grass/browser/sandbox/alexandris?order=name.
 I have reasons to support closing this ticket, after checking and updating
 all relevant modules or scripts that use them, of course!
 A reproducible session, below, to verify that:
 - i.rgb.his
     - supports for various input bitnesses (ie 8-bit Landsat 7, or 11-bit
 QuickBird2)
     - '''exports''' hue ranging in [0,360], intensity and saturation
 ranging in [0,1]
 - i.his.rgb
     - '''expects''' hue ranging in [0,360], intensity and saturation
 ranging in [0,1]
     - support for various output bitnesses
     - exports to user defined bitness, anything from 2 up to 16 (ie export
 to 6-bit [0,63], export to 8-bit [0,255], export to 16-bit [0,65535]
 '''Note, however,''' the modified versions of the modules break the
 current functionality of `i.pansharpen`. This is because the the intensity
 values, after the modified i.rgb.his, play between 0 and 1. Before,
 intensity was ranging in [0,255]. The fix should be, at least,
 conceptually, fairly easy. See also past discussions in #2048.
 # Reproducible session
 #!div style="font-size: 80%"
 {{{#!bash
 # check range of Landsat bands
 for BAND in 10 20 30; do echo `echo -e "Landsat band ${BAND}: " && r.info
 -r lsat7_2002_${BAND}` ;done
 Landsat band 10: min=42 max=255  # this is blue
 Landsat band 20: min=28 max=255  # this is green
 Landsat band 30: min=1 max=255   # this is red
 # convert (rgb) to his, 8-bit
 i.rgb.his r=lsat7_2002_30 g=lsat7_2002_20 bl=lsat7_2002_10 h=h8 i=i8 s=s8
 # rescale to 16-bit in order to test the `bits` option
 for BAND in 10 20 30; do r.rescale lsat7_2002_$BAND from=0,255
 output=lsat7_2002_${BAND}_16 to=0,65535 ;done
 Rescale lsat7_2002_10[0,255] to lsat7_2002_10_16[0,65535]
 Rescale lsat7_2002_20[0,255] to lsat7_2002_20_16[0,65535]
 Rescale lsat7_2002_30[0,255] to lsat7_2002_30_16[0,65535]
 # convert again, bits=16
 i.rgb.his r=lsat7_2002_30_16 g=lsat7_2002_20_16 bl=lsat7_2002_10_16 h=h16
 i=i16 s=s16 bits=16
 # check h, i, s output ranges, 8 & 16-bit
 for DIMENSION in h i s; do echo `echo "${DIMENSION}  8:" && r.info -r
 ${DIMENSION}8` && echo `echo -e "${DIMENSION} 16:" && r.info -r
 ${DIMENSION}16` ;done
 h 8: min=0 max=359.434
 h 16: min=0 max=359.434
 i 8: min=0.08431373 max=1
 i 16: min=0.08431373 max=1
 s 8: min=0 max=1
 s 16: min=0 max=1
 # convert (his) back to rgb
 i.his.rgb h=h8 i=i8 s=s8 r=r8 g=g8 bl=b8 bits=8
 i.his.rgb h=h16 i=i16 s=s16 r=r16 g=g16 bl=b16 bits=16
 # check rgb ranges
 for COLOR in r g b; do echo `echo "${COLOR}  8:" && r.info -r ${COLOR}8`
 && echo `echo -e "${COLOR} 16:" && r.info -r ${COLOR}16` ;done
 r 8: min=0 max=255
 r 16: min=256 max=65535
 g 8: min=28 max=255
 g 16: min=7195.999 max=65535
 b 8: min=42 max=255
 b 16: min=10794 max=65535
 # There is some "loss" or "smoothing" after the roundtrip. Note, for red
 the
 # minimum is now `1` and not `0`.
 # Some stats to verify
 # input 8-bit Landsat 7 bands
 for BAND in 10 20 30; do echo "lsat7_2002_${BAND} (8-bit): " && r.univar
 -g --q lsat7_2002_${BAND} && echo -e '\n' ;done
 lsat7_2002_10 (8-bit):
 n=250325
 null_cells=0
 cells=250325
 min=42
 max=255
 range=213
 mean=85.473624288425
 mean_of_abs=85.473624288425
 stddev=20.6960320098858
 variance=428.325740954217
 coeff_var=24.2133549175924
 sum=21396185
 lsat7_2002_20 (8-bit):
 n=250325
 null_cells=0
 cells=250325
 min=28
 max=255
 range=227
 mean=70.9216418655748
 mean_of_abs=70.9216418655748
 stddev=23.3183338152895
 variance=543.744691921275
 coeff_var=32.8790101327423
 sum=17753460
 lsat7_2002_30 (8-bit):
 n=250325
 null_cells=0
 cells=250325
 min=1
 max=255
 range=254
 mean=66.6989074203535
 mean_of_abs=66.6989074203535
 stddev=34.7033706761684
 variance=1204.32393628754
 coeff_var=52.029893769412
 sum=16696404
 # rescaled to 16-bit Landsat 7 bands
 for BAND in 10 20 30; do echo "lsat7_2002_${BAND} (16-bit): " && r.univar
 -g --q lsat7_2002_${BAND}_16 && echo -e '\n' ;done
 lsat7_2002_10 (16-bit):
 n=250325
 null_cells=0
 cells=250325
 min=10794
 max=65535
 range=54741
 mean=21966.7214421252
 mean_of_abs=21966.7214421252
 stddev=5318.88022654064
 variance=28290486.8642851
 sum=5498819545
 lsat7_2002_20 (16-bit):
 n=250325
 null_cells=0
 cells=250325
 min=7196
 max=65535
 range=58339
 mean=18226.8619594527
 mean_of_abs=18226.8619594527
 stddev=5992.81179052941
 variance=35913793.1567083
 sum=4562639220
 lsat7_2002_30 (16-bit):
 n=250325
 null_cells=0
 cells=250325
 min=257
 max=65535
 range=65278
 mean=17141.6192070309
 mean_of_abs=17141.6192070309
 stddev=8918.76626377528
 variance=79544391.667856
 sum=4290975828
 # his, 8-bit
 for DIMENSION in h i s; do echo "${DIMENSION} (8-bit): " && r.univar -g
 --q ${DIMENSION}8 && echo -e '\n' ;done
 h (8-bit):
 n=250007
 null_cells=318
 cells=250325
 min=0
 max=359.433959960938
 range=359.433959960938
 mean=232.677368810375
 mean_of_abs=232.677368810375
 stddev=47.0943195962118
 variance=2217.87493823014
 coeff_var=20.2401805714901
 sum=58170970.9441754
 i (8-bit):
 n=250325
 null_cells=0
 cells=250325
 min=0.084313727915287
 max=1
 range=0.915686272084713
 mean=0.294945252267712
 mean_of_abs=0.294945252267712
 stddev=0.10312914101826
 variance=0.0106356197271642
 coeff_var=34.9655199483101
 sum=73832.1702739149
 s (8-bit):
 n=250325
 null_cells=0
 cells=250325
 min=0
 max=1
 range=1
 mean=0.188441316597818
 mean_of_abs=0.188441316597818
 stddev=0.105874696347741
 variance=0.0112094513267264
 coeff_var=56.1844388795609
 sum=47171.5725773489
 # his, 16-bit
 for DIMENSION in h i s; do echo "${DIMENSION} (16-bit): " && r.univar -g
 --q ${DIMENSION}16 && echo -e '\n' ;done
 h (16-bit):
 n=250007
 null_cells=318
 cells=250325
 min=0
 i (16-bit):
 n=250325
 null_cells=0
 cells=250325
 max=1
 s (16-bit):
 n=250325
 null_cells=0
 cells=250325
 min=0
 max=1
 range=1
 # colors, 8-bit
 for COLOR in r g b; do echo "${COLOR} (8-bit):" && r.univar -g --q
 ${COLOR}8 &&
     echo -e '\n' ;done
 r (8-bit):
 n=250007
 null_cells=318
 cells=250325
 min=0
 max=255
 range=255
 mean=66.2976036670973
 mean_of_abs=66.2976036670973
 stddev=34.0979922976592
 variance=1162.67307873122
 coeff_var=51.4317115726787
 sum=16574865
 g (8-bit):
 n=250007
 null_cells=318
 cells=250325
 min=27.9999961853027
 max=255
 range=227.000003814697
 mean=70.6895694237074
 mean_of_abs=70.6895694237074
 stddev=22.3983713595429
 variance=501.687039559992
 coeff_var=31.6855393831711
 sum=17672887.1829128
 b (8-bit):
 n=250007
 null_cells=318
 cells=250325
 min=42
 max=255
 range=213
 mean=85.2600618087387
 mean_of_abs=85.2600618087387
 stddev=19.8145003705753
 variance=392.614424935528
 coeff_var=23.2400727259904
 sum=21315612.2726173
 # colors, 16-bit
 for COLOR in r g b; do echo "${COLOR} (16-bit):" && r.univar -g --q
 ${COLOR}16 && echo -e '\n' ;done
 r (16-bit):
 n=250007
 null_cells=318
 cells=250325
 min=256
 max=65535
 range=65279
 mean=17080.4321518997
 mean_of_abs=17080.4321518997
 stddev=8757.35508357642
 variance=76691268.0598418
 coeff_var=51.2712734999647
 sum=4270227601
 g (16-bit):
 n=250007
 null_cells=318
 cells=250325
 min=7195.9990234375
 max=65535
 range=58339.0009765625
 mean=18167.2193426611
 mean_of_abs=18167.2193426611
 stddev=5756.38144044411
 variance=33135927.2878894
 coeff_var=31.6855393875644
 sum=4541932006.20068
 b (16-bit):
 n=250007
 null_cells=318
 cells=250325
 min=10794
 max=65535
 range=54741
 mean=21911.8358886264
 mean_of_abs=21911.8358886264
 stddev=5092.32659532506
 variance=25931790.1534549
 coeff_var=23.2400727223788
 sum=5478112355.00781
Ticket URL: <http://trac.osgeo.org/grass/ticket/774#comment:13>
