[GRASS-dev] v.in.pygbif addon: Manual does not build
Helmut Kudrnovsky hellik at web.de
Tue Sep 13 07:28:32 PDT 2016
SBL wrote
> Hei,
> Does anyone have an idea why the v.in.pygbif addon-manual does not build?
> I managed to install it through g.extension and it works fine.
> The pygbif library is a dependency of v.in.pygbif. Therefore, I tried to
> align dependency handling (import) with the working solution in
> v.class.mlpy as another module with external dependencies. That obviously
> did not help, unfortunately.
> Are error logs from the automatic builds available online somewhere I
> could check?
> I have some uncommitted modifications for the module I like to commit. It
> would be great to fix the built of the manual in one go.
> Thanks for helping in advance.
the logs from tha addon builds for winGRASS can be found here:
https://wingrass.fsv.cvut.cz/grass73/x86_64/addons/grass-7.3.svn/logs/
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-in-pygbif-addon-Manual-does-not-build-tp5285571p5285572.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
