[GRASS-dev] v.in.pygbif addon: Manual does not build
Helmut Kudrnovsky hellik at web.de
Tue Sep 13 07:52:29 PDT 2016
>Thanks for your swift reply!
>In v.in.pygbif the import of pygbif is also done in a try-except statement.
>Maybe the difference is that pyspatialite is installed on the build system,
while pygbif is (naturally) not >(yet)?
https://trac.osgeo.org/grass/browser/grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py#L179
179	try:
180	    from pygbif import occurrences
181	    from pygbif import species
182	except ImportError:
183	    grass.fatal(_("Cannot import pygbif
(https://github.com/sckott/pygbif)"
184	                  " library."
185	                  " Please install it (pip install pygbif)"
186	                  " or ensure that it is on path"
187	                  " (use PYTHONPATH variable)."))
188
189
190	def main():
the difference ist that in v.in.natura2000 it's done in def main(); in
v.in.pygbif it's done before def main()
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-in-pygbif-addon-Manual-does-not-build-tp5285571p5285580.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
