[GRASS-dev] [GRASS GIS] #3159: No label in output when using a point vector layer as in put in r.what
GRASS GIS trac at osgeo.org
Wed Sep 14 22:19:09 PDT 2016
 Reporter:  pvanbosgeo   |      Owner:  grass-dev@…
     Type:  enhancement  |     Status:  new
 Priority:  normal       |  Milestone:  7.0.5
Component:  Default      |    Version:  unspecified
 Keywords:               |        CPU:  Unspecified
 Platform:  Unspecified  |
 In ''r.what'' one can provide as input a text file with coordinates and
 optionally a label, both which will be printed to the output file as well.
 If using a point vector layer as input, there is no option to define the
 label. The output text file includes two columns with the coordinates and
 an empty column for the label.
 It would be nice if one could define a column to serve as label, or
 alternatively, to have ''r.what'' fill in the label column with the cat
 values.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3159>
