[GRASS-dev] [GRASS GIS] #3161: different results by v.in.ogr --ui and vector import wizzard (data shift)
GRASS GIS trac at osgeo.org
Sun Sep 18 13:45:27 PDT 2016
  Reporter:  hellik   |      Owner:  grass-dev@…
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  7.2.0
 Component:  Vector   |    Version:  svn-trunk
Resolution:           |   Keywords:  vector import
       CPU:  x86-64   |   Platform:  MSWindows 7
Comment (by hellik):
 Replying to [comment:1 mmetz]:
 > In the end, the user has to decide if reprojection is needed or if the
 source srs and the location srs are similar enough to allow for using
 v.in.ogr -o (override projection check). After investigating the input
 data with g.proj georef=<data to be imported> and ogrinfo/gdalinfo.
 as mentioned before, there is no ''override projection check'' needed by
 import via v.in.ogr --ui.
 if you want to try
 - data can be downloaded
 [https://www.tirol.gv.at/data/datenkatalog/umwelt/gewaessernetz/ river
 net];
 - then ogr2ogr -s_srs EPSG:31254 -t_srs EPSG:31287
 - create location by EPSG:31287 and datum_trans 2
 - then import ''GUI -> import common formats''
Ticket URL: <https://trac.osgeo.org/grass/ticket/3161#comment:4>
