[GRASS-dev] GRASS_COMPRESSOR=BZIP2 in winGRASS
Helmut Kudrnovsky hellik at web.de
Mon Sep 19 07:14:47 PDT 2016
>2016-09-18 20:04 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
>>> "GRASS needs to be compiled with BZIP2 for BZIP2 compression"
>> I checked
>> https://wingrass.fsv.cvut.cz/grass73/x86_64/logs/log-r69510-8/
>> BZIP2 support: no
>> That's why it is at time not included in winGRASS...
>bzlib2 support activated in trunk (r69517). Let's check the next
>WinGRASS build. Martin
tested with today's winGRASS daily:
echo %GRASS_COMPRESSOR%
BZIP2
r.mapcalc expression=checkcompression = elevation at PERMANENT / 2
r.compress -p map=checkcompression at checkbzip2
<checkcompression> is compressed (method 4: BZIP2). Data type: FCELL
thanks for activating BZIP2 compression.
best
Helmut
