[GRASS-dev] [GRASS GIS] #3165: v.out.ogr -c seg fault
GRASS GIS trac at osgeo.org
Thu Sep 22 02:33:40 PDT 2016
  Reporter:  ychemin  |      Owner:  grass-dev@…
      Type:  defect   |     Status:  new
  Priority:  normal   |  Milestone:  7.0.5
 Component:  Vector   |    Version:  svn-trunk
Resolution:           |   Keywords:  v.out.ogr
       CPU:  x86-64   |   Platform:  Linux
Comment (by ychemin):
 ==9324== Memcheck, a memory error detector
 ==9324== Copyright (C) 2002-2015, and GNU GPL'd, by Julian Seward et al.
 ==9324== Using Valgrind-3.12.0.SVN and LibVEX; rerun with -h for copyright
 info
 ==9324== Command: v.out.ogr -e -c input=indices type=area
 output=//home/yann/Desktop/watersheds/img1_4/out.shp layer=1
 format=ESRI_Shapefile --overwrite
 ==9324==
 WARNING: The map contains islands. With the -c flag, islands will appear
 as
          filled areas, not holes in the output map.
 ==9324== Use of uninitialised value of size 8
 ==9324==    at 0x507515D: Vect_get_centroid_area (level_two.c:440)
 ==9324==    by 0x10DFBF: export_areas_single (export_areas.c:81)
 ==9324==    by 0x10DFBF: export_areas (export_areas.c:33)
 ==9324==    by 0x10CCC1: main (main.c:737)
 ==9324==
 ==9324== Invalid read of size 1
 ==9324==  Address 0x0 is not stack'd, malloc'd or (recently) free'd
 ==9324==
 ==9324==
 ==9324== Process terminating with default action of signal 11 (SIGSEGV)
 ==9324==  Access not within mapped region at address 0x0
 ==9324==  If you believe this happened as a result of a stack
 ==9324==  overflow in your program's main thread (unlikely but
 ==9324==  possible), you can try to increase the size of the
 ==9324==  main thread stack using the --main-stacksize= flag.
 ==9324==  The main thread stack size used in this run was 8388608.
 ==9324==
 ==9324== HEAP SUMMARY:
 ==9324==     in use at exit: 24,336,088 bytes in 932,399 blocks
 ==9324==   total heap usage: 978,460 allocs, 46,061 frees, 29,688,816
 bytes allocated
 ==9324==
 ==9324== LEAK SUMMARY:
 ==9324==    definitely lost: 602 bytes in 30 blocks
 ==9324==    indirectly lost: 2,261 bytes in 114 blocks
 ==9324==      possibly lost: 0 bytes in 0 blocks
 ==9324==    still reachable: 24,333,225 bytes in 932,255 blocks
 ==9324==         suppressed: 0 bytes in 0 blocks
 ==9324== Rerun with --leak-check=full to see details of leaked memory
 ==9324==
 ==9324== For counts of detected and suppressed errors, rerun with: -v
 ==9324== Use --track-origins=yes to see where uninitialised values come
 from
 ==9324== ERROR SUMMARY: 2 errors from 2 contexts (suppressed: 0 from 0)
 /home/yann/Desktop/watersheds/script.sh: line 383:  9324 Segmentation
 fault      (core dumped) valgrind --tool=memcheck v.out.ogr -e -c
 input=indices type=area output=$GIS_OPT_SHNAME layer=1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3165#comment:4>
