[GRASS-dev] t.register: ERROR: Unable to register raster map - The map has no timestamp and the start time is not set.
Helmut Kudrnovsky hellik at web.de
Sun Sep 25 02:26:36 PDT 2016
>Hi,
>remove option "separator=newline". It should only be used if there are
time-stamps in the file.
>Best regards
>Soeren
t.register -i --verbose input=precipitation_sum_1950_2015_daily at ecad
file=/home/bugs/wd/climate_data/ecad/prec_list.txt start=1950-01-01
increment=1 days
Gathering map information...
Registering maps in the temporal database...
Registering maps in the space time dataset...
Updating space time dataset...
Update metadata, spatial and temporal extent from all registered maps of
<precipitation_sum_1950_2015_daily at ecad>
is registering now.
from the manual:
unit=string
    Time stamp unit
    Unit must be set in case of relative time stamps
    Options: years, months, days, hours, minutes, seconds
in the case of this data set, is it necessary to define the unit?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/t-register-ERROR-Unable-to-register-raster-map-The-map-has-no-timestamp-and-the-start-time-is-not-se-tp5287609p5287613.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
