[GRASS-dev] Adding an expert mode to the parser
Markus Neteler neteler at osgeo.org
Sun Sep 25 12:49:11 PDT 2016
On Fri, Sep 23, 2016 at 11:30 PM, Markus Metz
<markus.metz.giswork at gmail.com> wrote:
> On Fri, Sep 23, 2016 at 11:22 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Fri, Sep 23, 2016 at 11:05 PM, Markus Metz
>>> On Fri, Sep 23, 2016 at 1:11 PM, Markus Neteler <neteler at osgeo.org> wrote:
>>> Your motivation is to provide a specialized CLI interface for HPC
>>> processing?
>> No, not the case.
>>> We used GRASS with HPC processing for years and the
>>> problems we faced were causes by the HPC hardware and software
>>> infrastructure, not by GRASS. What exactly is the problem with using
>>> GRASS and HPC processing?
>> There is no problem. There is just the issue that with an increasing
>> amount of additions (e.g. maybe the need to provide region/resolution
>> to individual modules for independent parallel processing without the
>> overhead of always opening a new mapset)
> Getting closer it seems. Can you quantify "the overhead of always
> opening a new mapset"?
As an example, when aiming at processing all Sentinel-2 tiles
globally, we speak about currently 73000 scenes * up-to-16 tiles along
with global data, analysis on top of other global data is more complex
when doing each job in its own mapset and reintegrate it in a single
target mapset as if able to process then in parallel in one mapset by
simply specifying the respective region to the command of interest.
Yes, different from the current paradigm and not for G7.
But my original comment was targeted at the increasing number of
module parameters and how to handle that (with some new HPC related
idea as an example).
I'm fine to archive this question for now, it will likely come up
again in the future.
markusN
