[GRASS-dev] [GRASS GIS] #3167: db.connect: connection to remote database does not work
GRASS GIS trac at osgeo.org
Mon Sep 26 23:01:39 PDT 2016
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  blocker      |  Milestone:  7.0.5
 Component:  Database     |    Version:  unspecified
Resolution:               |   Keywords:  postgresql db.connect
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:4 mlennert]:
 > Replying to [comment:2 martinl]:
 > > Replying to [ticket:3167 mlennert]:
 > > > createdb -h myRemoteServer testgrass
 > > > grass70 -c /data/GRASS/DATA7/nc_spm_08/postgres_test
 > > > db.connect driver=pg database="host=myRemoteServer,dbname=testgrass"
 > > did you tried
 > > db.connect driver=pg database=testgrass
 > > db.login driver=pg database=testgrass host=myRemoteServer
 I just noticed that the first sentence with the most important information
 is missing:
 Yes, I tried, but it didn't make a difference. Exact same error as before
 and DEBUG=3 gives me:
 D3/3: db_driver_open_database(): host = (null), port = (null), options =
 (null), tty = (null), dbname = testgrass, user = (null), password = (null)
 schema = (null)
 > And if this is how it is supposed to be done, then we need to change the
 man page.
 > It just seems a bit redundant to have to indicate driver and database
 twice...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3167#comment:7>
