[GRASS-dev] [GRASS GIS] #3167: db.connect: connection to remote database does not work
GRASS GIS trac at osgeo.org
Mon Sep 26 23:43:00 PDT 2016
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  blocker      |  Milestone:  7.0.5
 Component:  Database     |    Version:  unspecified
Resolution:               |   Keywords:  postgresql db.connect
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Getting closer:
 The issue seems to be in the reading of the dblogin file.
 My file contains;
 pg|testgrass|||myRemoteHost|
 But the debug message show:
 D3/3: read_file(): DB login file = </home/mlennert/.grass7/dblogin>
 D3/3: ret = 2 : drv=[pg] db=[testgrass] usr=[] pwd=[] host=[], port=[]
 Looking at the sscanf call that reads the data from the file (in
 lib/db/dbmi_base/login.c, line 118, I see:
         ret = sscanf(buf, "%[^|]|%[^|]|%[^|]|%[^|]|%[^|]|%[^\n]",
                      dr, db, usr, pwd, host, port);
 Somehow this doesn't seem to read the line as it should...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3167#comment:9>
