[GRASS-dev] [GRASS GIS] #2445: r.mask -r removal not working in GRASS 7.1 svn r.62210
GRASS GIS trac at osgeo.org
Thu Sep 29 00:28:15 PDT 2016
  Reporter:  baharmon     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.2.0
 Component:  Raster       |    Version:  svn-trunk
Resolution:               |   Keywords:  r.mask
       CPU:  Unspecified  |   Platform:  MSWindows 8
Comment (by mlennert):
 Could anyone test this on Windows, i.e. create a raster file named mask
 (lowercase) and then attempt 'g.remove type=rast pattern=MASK -f' and
 'g.remove -i type=rast pattern=MASK' ?
 And if the first doesn't work, but the second does could the following
 lines in r.mask:
             grass.run_command('g.remove', flags='f', quiet=True,
                               type='raster', name='MASK')
 be replaced by
             grass.run_command('g.remove', flags='fi', quiet=True,
 if we are in Windows ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2445#comment:9>
