[GRASS-dev] [GRASS GIS] #2960: db.login port parameter
GRASS GIS trac at osgeo.org
Thu Sep 29 12:38:51 PDT 2016
  Reporter:  lucadelu     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  closed
  Priority:  major        |  Milestone:  7.2.0
 Component:  Database     |    Version:  svn-trunk
Resolution:  fixed        |   Keywords:  database, postgresql, db.login
       CPU:  Unspecified  |   Platform:  Unspecified
Changes (by martinl):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Replying to [comment:5 mlennert]:
 > I imagine that this is the same issue as #3167 which was fixed. Could
 you see if you still have this issue ?
 Right, seems to be like that. I tested PG database cluster running on port
 5433.
 db.login dri=pg data=db port=5433
 db.tables -p
 Worked. Closing, feel free to re-open if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2960#comment:6>
