[GRASS-dev] r.pi installation fails
Markus Metz markus.metz.giswork at gmail.com
Tue Apr 25 13:14:09 PDT 2017
On Tue, Apr 25, 2017 at 3:31 PM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> On 07/04/17 14:05, Markus Metz wrote:
>> If you compile GRASS from source, you can svn checkout the r.pi folder,
>> manually run make and (as root) make install.
> Trying this, I get two errors while compiling:
> make[1] : on entre dans le répertoire «
/data/home/mlennert/SRC/GRASS/grass-addons/grass7/raster/r.pi/r.pi.grow »
> and
/data/home/mlennert/SRC/GRASS/grass-addons/grass7/raster/r.pi/r.pi.lm »
Fixed in r70952. Please test (not only compilation, but also actual
results).
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170425/7723a960/attachment.html>
