[GRASS-dev] [GRASS GIS] #3341: g.search.modules depends on grass-gui
GRASS GIS trac at osgeo.org
Fri Apr 28 05:48:17 PDT 2017
 Reporter:  martinl           |      Owner:  grass-dev@…
     Type:  defect            |     Status:  new
 Priority:  minor             |  Milestone:  7.2.1
Component:  Packaging         |    Version:  unspecified
 Keywords:  g.search.modules  |        CPU:  Unspecified
 Platform:  Unspecified       |
 In distributions like !Debian/Ubuntu GRASS is split into more packages
 like `grass-core` and `grass-gui`. Currently G72:g.search.modules (shifted
 by `grass-core`) depends on XML (gui/wxpython/xml/module_items.xml) which
 is shifted by `grass-gui` package.
 Currently the command fails (no `grass-gui` package not installed).
 RASS 7.2.0 (landsat):~ > g.search.modules buffer
   File "/usr/lib/grass72/scripts/g.search.modules", line 246, in <module>
     sys.exit(main())
   File "/usr/lib/grass72/scripts/g.search.modules", line 81, in main
     modules = _search_module(keywords, AND, manpages)
   File "/usr/lib/grass72/scripts/g.search.modules", line 176, in
 _search_module
     menudata_file = open(filename, 'r')
 IOError: [Errno 2] No such file or directory:
 '/usr/lib/grass72/gui/wxpython/xml/module_items.xml'
 Solution: GUI XML files could be moved to 'etc' directory.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3341>
