[GRASS-dev] GRASS flyer for the new osgeo branding
Luca Delucchi lucadeluge at gmail.com
Tue Aug 1 23:39:10 PDT 2017
On 1 August 2017 at 23:22, Stefan Blumentrath
<Stefan.Blumentrath at nina.no> wrote:
> Hi again,
Hi Stefan,
> Please find attached two documents where I try to illustrate the suggested changes (with https://github.com/lucadelu/osgeo/blob/ab18927d18bd73bbb58201b2612f608ffbfa8a08/marketing/print/grass_a4.svg as reference).
> The TXT is in diff style (removed content starts with a "-" on the line, added content with a "+") and in the ODT I had "track changes" activated.
> Hope that helps to identify the proposals for changes.
Not really (I cannot see the changes in the ODT, the diff is not
really a diff :-P, and you used an older version of the svg ) but:
- I will try to merge your proposals
- Some of you proposal are to difficult to accept because they will
change to much the structure of the text and I have not time to modify
everything
> Cheers
> Stefan
ciao
Luca
www.lucadelu.org
