[GRASS-dev] New attempt to update GRASS for Mac
Michael Barton Michael.Barton at asu.edu
Fri Aug 4 14:58:59 PDT 2017
I'm very glad you've found a way forward. Perhaps someone else on this thread can suggest how it might be incorporated into the GRASS build system. I have several questions below, that are a result of my spotty understanding (or ignorance) of the details of build systems.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Aug 4, 2017, at 3:50 PM, Eric Hutton <hutton.eric at gmail.com<mailto:hutton.eric at gmail.com>> wrote:
Hi Michael
I found that if I manually add linker flags (like "-L$PREFIX/lib -liconv") I was able to get rid of these errors.
Where do you add these? In every GRASS module? Or someplace more general?
I also notice that I had to append them to the end of the compile command (or at least after things like "-lgrass_gis.7.2.0" - I guess it has to do with the order that the compiler looks at libraries to resolve sysbols).
Again, where does this go?
Then, at runtime $PREFIX/lib needed to appear in the LD_LIBRARY_PATH_VAR when running the tests.
Can I just add this to my .profile or run this the shell I've opened to compile GRASS prior to configure?
I'm not sure of the best way to fix this within the grass build system (simply adding the link flags to LDFLAGS didn't do the trick). Perhaps tweaking Rules.make and the like would do the trick? I think the basic problem is that conda does the entire build within a temporary folder that contains installations of all the dependencies and that this temporary folder is not added to all the necessary places.
When you say that "conda does the entire build...", are you referring to building/installing the dependencies? Or are you referring to building GRASS? So far, I've been trying to build GRASS from the shell, like I've done it before, but giving the conda paths to dependencies instead of /System/Frameworks/...
Michael
Eric
On Fri, Aug 4, 2017 at 3:05 PM Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
After a tedious set of tests, I can say that GRASS will not build with ANY dependency from Anaconda except SQLite. That is, I went through the dependencies one-by-one and replaced the path to a Framework version with an Anaconda version in my configure string. I did a make clean between each build attempt.
All the versions are close (secondary or tertiary version number) or identical between William's framework builds and those in Anaconda.
For FreeType and Cairo, the errors of the type I posted yesterday
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
For the other dependencies, the errors are that the appropriate library cannot be found, like the following for fftw:
dyld: Library not loaded: @rpath/libfftw3.3.dylib
  Referenced from: /Users/cmbarton/grass_source/trunk/dist.x86_64-apple-darwin16.7.0/lib/libgrass_gmath.7.3.svn.dylib
  Reason: image not found
It seems to me like there has to be some kind of systematic reason for this not to work. Something hardwired in a key makefile or something. The Anaconda packages are all current builds of normal dependencies.
I am even doing it in an environment in which /Applications/anaconda/bin is first in my PATH (which works fine if the dependencies are Frameworks).
Any thoughts on this?
Michael
C. Michael Barton
voice:  480-965-6262<tel:(480)%20965-6262> (SHESC), 480-965-8130<tel:(480)%20965-8130>/727-9746 (CSDC)
fax: 480-965-7671<tel:(480)%20965-7671> (SHESC),  480-727-0709<tel:(480)%20727-0709> (CSDC)
www: http://www.public.asu.edu/~cmbarton<https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=KtrgOgv-4RMiEJEdKKQg5Z_ZL4pv8gJw3U0lH7fV_jg&s=LIHaJSGN6aEh018lfLuD_oohvcwC4GRCW2pleRj90HE&e=>, http://csdc.asu.edu<https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=KtrgOgv-4RMiEJEdKKQg5Z_ZL4pv8gJw3U0lH7fV_jg&s=ZZ_j-P8_GLz4WT29WIipvPXFuAZoZlYUntcjvNtYEOs&e=>
On Aug 4, 2017, at 12:56 AM, Moritz Lennert <mlennert at club.worldonline.be<mailto:mlennert at club.worldonline.be>> wrote:
On 04/08/17 00:33, Vaclav Petras wrote:
Well, the error (below) suggests that wrong library is either linked or included. You need to go through the -L and -I paths and see if you need to set one of these differently or add additional one for iconv. I don't see how to set this through ./configure (I don't see any --with-iconv-includes= or --with-iconv-libs=), but you can start by editing the Makefiles or the command itself and changing -L and -I directly.
Undefined symbols for architecture x86_64:
  "_iconv", referenced from:
      _draw_main in text3.o
  "_iconv_close", referenced from:
  "_iconv_open", referenced from:
Just guessing: Could the error be linked to the use of clang ? Have you tried with gcc ?
Moritz
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170804/d46f8224/attachment-0001.html>
