[GRASS-dev] Dockerfile now in repo
Vaclav Petras wenzeslaus at gmail.com
Mon Aug 7 17:29:16 PDT 2017
On Mon, Aug 7, 2017 at 6:35 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Thanks for the Dockerfile, Vaclav!
> On Sun, Jul 30, 2017 at 1:11 AM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
> > [Using the thread with the announcement for this answer.]
> > It is the Dockerfile. You let Docker build a Docker image using that file
> > (Docker looks to the directory specified and finds the Dockerfile, kind
> of
> > like make and Makefile). You then use Docker to run a process in the
> > container derived from that image. GRASS GIS is build as part of
> building of
> > the image. See the readme file for examples:
> > https://trac.osgeo.org/grass/browser/grass/trunk/README#L53
> what do you think of the suggested changes?
> https://lists.osgeo.org/pipermail/grass-dev/2017-July/085633.html
> I attach the modified Dockerfile which I tested on Fedora (still
> creating the Ubuntu docker image). Appears to work fine.
If that works with the Docker image, I'm for it. I'm just not sure about
pthreads. The fact that r.mapcalc is not using them does not mean that some
addon module won't use them (and thus need them in the configuration). I'm
afraid the package list is originally from some other source, like the wiki.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170807/b14210fc/attachment.html>
