[GRASS-dev] [GRASS GIS] #3391: r.learn.ml : the list of caterory map indices is not handled properly.
GRASS GIS trac at osgeo.org
Wed Aug 9 05:26:03 PDT 2017
 Reporter:  maitl   |      Owner:  grass-dev@…
     Type:  defect  |     Status:  new
 Priority:  normal  |  Milestone:  7.2.2
Component:  Addons  |    Version:  unspecified
 Keywords:          |        CPU:  All
 Platform:  All     |
 # convert to lists
     if ',' in categorymaps:
         categorymaps = [int(i) for i in categorymaps.split(',')]
         print(categorymaps)
     else: categorymaps = None
 fails if there is only one category map.
 The proposed solution is
 if categorymaps.strip() == '':
         categorymaps = None
     else:
         try:
             categorymaps = [int(i.strip()) for i in
             # negatiivse ja maplist, _ = maps_from_group(group) suurima
 indeksi kontroll, dublikaatide kontroll (unique)
             nCategories = len(maps_from_group(group)[0])
             if min(categorymaps) < 0:
                 gscript.fatal('Category map index can not be negative.')
             if max(categorymaps) > nCategories - 1:
                 gscript.fatal('Category map index input can not exceed ' +
 str(nCategories - 1))
             if not len(np.unique(categorymaps)) == len(categorymaps):
                 gscript.fatal('Duplicate indices in category map index
 list.')
         except:
             gscript.fatal('Error in category map list input.')
     if ',' in indexes:
         indexes = [int(i) for i in indexes.split(',')]
     else:
         indexes = int(indexes)
     if indexes == -1: indexes = None
 # credits for this fix go to Jaan Janno from Tartu University, Estonia
Ticket URL: <https://trac.osgeo.org/grass/ticket/3391>
