[GRASS-dev] [GRASS GIS] #3392: t.register: encoding error
trac at osgeo.org
Fri Aug 11 01:36:09 PDT 2017
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Temporal | Version: svn-trunk
Resolution: | Keywords: t.register encoding
CPU: Unspecified | Platform: Unspecified
Comment (by zarch):
Replying to [comment:1 zarch]:
> Replying to [ticket:3392 mlennert]:
> > Using the data and examples from [http://ncsu-geoforall-lab.github.io
/grass-temporal-workshop/ 1] in a french (fr_BE at UTF-8) encoding
environment, I get an encoding error using t.register:
> I was able to reproduce the error, actually the #3394, and with the
attached patch is working on my PC.
> Can you test it?
I remembered that once Glynn in grass-dev (2016-05-05) said:
''"Anything using the script module should be using byte strings
throughout (in spite of how awkward Python 3 tries to make this)."''
So I think that instead of returning unicode as I did in the first patch
we should return bytes...
Please apply the two diff files, and let me know if it is working for you.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3392#comment:2>
