[GRASS-dev] [GRASS GIS] #3392: t.register: encoding error
GRASS GIS trac at osgeo.org
Fri Aug 11 02:41:42 PDT 2017
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.2.2
 Component:  Temporal     |    Version:  svn-trunk
Resolution:               |   Keywords:  t.register encoding
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:2 zarch]:
 > Replying to [comment:1 zarch]:
 > > Replying to [ticket:3392 mlennert]:
 > > > Using the data and examples from [http://ncsu-geoforall-
 lab.github.io/grass-temporal-workshop/ 1] in a french (fr_BE at UTF-8)
 encoding environment, I get an encoding error using t.register:
 > > I was able to reproduce the error, actually the #3394, and with the
 attached patch is working on my PC.
 > > Can you test it?
 > I remembered that once Glynn in grass-dev (2016-05-05) said:
 > ''"Anything using the script module should be using byte strings
 throughout (in spite of how awkward Python 3 tries to make this)."''
 > So I think that instead of returning unicode as I did in the first patch
 we should return bytes...
 > Please apply the two diff files, and let me know if it is working for
 you.
 I've applied your patches (BTW: it is always best to make diffs relative
 to the source tree root. That way one doesn't have to search for where the
 patched files are...).
 t.create output=pluies_nc semantictype=sum title=precipitation_mois
 description="Précipitation totale mensuelle NC"Traceback (most recent call
 last):
   File "/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
 gnu/scripts/t.create", line 86, in <module>
     main()
 gnu/scripts/t.create", line 82, in main
     semantic, None, grass.overwrite())
 gnu/etc/python/grass/temporal/open_stds.py", line 174, in open_new_stds
     sp.insert(dbif)
 gnu/etc/python/grass/temporal/abstract_space_time_dataset.py", line 381,
 in insert
     statement += AbstractDataset.insert(self, dbif=dbif, execute=False)
 gnu/etc/python/grass/temporal/abstract_dataset.py", line 398, in insert
     statement += self.metadata.get_insert_statement_mogrified(dbif)
 gnu/etc/python/grass/temporal/base.py", line 404, in
     mapset=self.mapset)
 gnu/etc/python/grass/temporal/core.py", line 946, in mogrify_sql_statement
     return self.connections[mapset].mogrify_sql_statement(content)
 gnu/etc/python/grass/temporal/core.py", line 1216, in
     unicode(args[count]),
 UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 2:
 ordinal not in range(128)
 However:
 description="Precipitation totale mensuelle NC"
 Note the accent in the description of the first try, but not the second.
 This wasn't a problem before applying your patch.
 Then
 t.register -i input=pluies_nc at climate_2000_2012
 file=fichier_cartes_tempmean start=2000-01-01 increment="1 months"
 Collecte des informations sur la carte ...
  100%
 Enregistrement des cartes dans la base temporelle ...
 Enregistrement des cartes dans le jeu de données temporel ...
 Mise à jour du jeu de données temporel ...
 ERREUR :ascii,Mettre à jour les métadonnées, l'emprise spatiale et
         temporelle de toutes les cartes enregistrées de <,7,8,ordinal not
         in range(128)
 And :
 t.unregister file=fichier_cartes_tempmean
 Unregister maps
  100%
 Unregister maps from the temporal database
 gnu/scripts/t.unregister", line 183, in <module>
     tgis.profile_function(main)
 gnu/etc/python/grass/temporal/core.py", line 85, in profile_function
     func()
 gnu/scripts/t.unregister", line 169, in main
     sp.update_from_registered_maps(dbif)
 gnu/etc/python/grass/temporal/abstract_space_time_dataset.py", line 2295,
 in update_from_registered_maps
     " all registered maps of <%s>") % (self.get_id()))
 UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 7:
 And:
 t.remove pluies_nc -fNote: registered maps themselves have not been
 removed, only the strds
 gnu/scripts/t.remove", line 171, in <module>
     func()
 gnu/scripts/t.remove", line 157, in main
     statement += sp.delete(dbif=dbif, execute=False)
 gnu/etc/python/grass/temporal/abstract_space_time_dataset.py", line 1959,
 in delete
     self.get_id()))
 UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 23:
 If this is a fundamental issue in the temporal modules then we should
 probably keep the discussion centralized here. I'll close the other bug
 reports as duplicates of this one.
 t.info (#3394) and t.rast.extract (#3395) now work, but I suspect that the
 errors there came from the accent in the description of the strds.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3392#comment:4>
