[GRASS-dev] [GRASS GIS] #3392: t.register: encoding error
GRASS GIS trac at osgeo.org
Fri Aug 11 15:47:27 PDT 2017
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.2.2
 Component:  Temporal     |    Version:  svn-trunk
Resolution:               |   Keywords:  t.register encoding
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by huhabla):
 Replying to [comment:9 mlennert]:
 > Maybe the solution needs to be found in lib/python/pygrass/messages ?
 Good point. I have tried to fix this issue and attached the
 "pygrass_temporal_gis_utf_handling.diff​" that must be applied to fresh
 trunk.
 Can you please test the changes? I am not able to convince my GRASS
 installation to use the German locale that i have set, so its a kind of
 dry test.
 https://trac.osgeo.org/grass/raw-
 attachment/ticket/3392/pygrass_temporal_gis_utf_handling.diff
Ticket URL: <https://trac.osgeo.org/grass/ticket/3392#comment:10>
