[GRASS-dev] Inclusion of additional files with add-on
Steven Pawley dr.stevenpawley at gmail.com
Sat Aug 12 13:22:59 PDT 2017
Thanks Markus for the pointer, I will take a look.
Steve
On Sat, Aug 12, 2017 at 1:35 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Aug 12, 2017 9:34 PM, "Markus Neteler" <neteler at osgeo.org> wrote:
> > On Aug 12, 2017 4:45 PM, "Steven Pawley" <dr.stevenpawley at gmail.com>
> wrote:
> > > Hello,
> > > I'm getting around to completing my TODO list for the add-on
> r.terrain.texture, which includes generating the additional terrain metrics
> (terrain surface concavity and convexity), and calculating the nested 8,12
> or 16 class terrain classification as per Iwahashi and Pike (2007).
> Everything is working but the script uses r.mfilter, which I supply a
> matrix filter to, stored as a text file.
> > > Is there a makefile command that can be used to bundle a text file
> with the add on, which can then be found using set_path?
> > You may want to check how the color files are installed. Should work
> pretty much the same.
> I meant the Makefile in lib/gis/
> Markus
> > > Steve
> > > _______________________________________________
> > > grass-dev mailing list
> > > grass-dev at lists.osgeo.org
> > > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170812/b5b278a7/attachment.html>
