[GRASS-dev] Inclusion of additional files with add-on
Helmut Kudrnovsky hellik at web.de
Tue Aug 15 00:31:24 PDT 2017
>I have gone with your's and Moritz's suggestion and have completed
r.terrain.texture with the Iwahashi >and Pike nested-means terrain
classification method in the add-ons.
addon tested here with
System Info
GRASS version: 7.3.svn
GRASS SVN revision: r71384
Build date: 2017-08-11
Build platform: x86_64-w64-mingw32
GDAL: 2.2.1
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
and
r.terrain.texture elevation=elevation at PERMANENT slope=myslope at user1
classes=12 texture=terr_tex convexity=terr_convex concavity=terr_concav
features=terr_class
I get
features=terr_class
Calculating terrain surface texture...
1. Smoothing input DEM with a 3x3 median filter...
2. Extracting pits and peaks with difference > thres...
3. Using resampling filter to create terrain texture...
4. Converting to percentage...
Calculating terrain convexity and concavity...
1. Calculating terrain curvature using laplacian filter...
2. Extracting convexities and concavities...
3. Using resampling filter to create surface convexity/concavity...
4. Converting to percentages...
Performing terrain surface classification...
  File
"C:\OSGEO4~1\apps\grass\grass-7.3.svn/scripts/m.proj.py",
line 308, in <module>
    main()
  File
line 243, in main
    inf = file(infile)
IOError: [Errno 13] Permission denied: 'c:\\users\\xxx\\ap
pdata\\local\\temp\\grass7-hkmyr-6804\\tmpl1pwdf'
ERROR: cs2cs failed
Deleting intermediate files...
WARNING: No data base element files found
  File "C:\Users\xxx\AppData\Roaming\GRASS7\addons/scripts
/r.terrain.texture.py", line 575, in <module>
    sys.exit(main())
/r.terrain.texture.py", line 471, in main
    flags='g', quiet=True,
stdout_=PIPE).outputs.stdout.split(os.linesep)[:-1]
  File "C:\OSGEO4~1\apps\grass\grass-7.3.svn\etc\python\gras
s\pygrass\modules\interface\module.py", line 648, in
__call__
    return self.run()
s\pygrass\modules\interface\module.py", line 769, in run
    self.wait()
s\pygrass\modules\interface\module.py", line 790, in wait
    module=self.name, errors=stderr)
grass.exceptions.CalledModuleError: Module run r.tileset
r.tileset sourceproj=+proj=lcc +lat_1=36.16666666666666
+lat_2=34.33333333333334 +lat_0=33.75 +lon_0=-79
+x_0=609601.22 +y_0=0 +no_defs +a=6378137 +rf=298.257222101
+towgs84=0.000,0.000,0.000 +to_meter=1 sourcescale=1
maxcols=1500 maxrows=1352 overlap=0 separator=pipe -g --q
ended with error
Process ended with non-zero return code 1. See errors in the
(error) output.
C:\>where cs2cs
C:\OSGeo4W64\bin\cs2cs.exe
C:\>cs2cs
Rel. 4.9.3, 15 August 2016
usage: cs2cs [ -eEfIlrstvwW [args] ] [ +opts[=arg] ]
                   [+to [+opts[=arg] [ files ]
cs2cs seems to be available.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Inclusion-of-additional-files-with-add-on-tp5331342p5331497.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
