[GRASS-dev] Inclusion of additional files with add-on
Steven Pawley dr.stevenpawley at gmail.com
Wed Aug 16 09:03:55 PDT 2017
I'll open a ticket for r.tileset.
Sent from my iPhone
> On Aug 16, 2017, at 2:36 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
> Moritz Lennert wrote
>>> On 16/08/17 00:48, Steven Pawley wrote:
>>> This seems to be an issue on windows that is related to r.tileset not
>>> r.terrain.texture. Infact on windows I can't get r.tileset to function
>>> at all on a windows system, but it works on linux:
>>> r.tileset sourceproj="+proj=tmerc +lat_0=0 +lon_0=-115 +k=0.9992
>>> +x_0=500000 +y_0=0 +no_defs +a=6378137 +rf=298.257222101
>>> +towgs84=0.000,0.000,0.000 +to_meter=1"
>>> Traceback (most recent call last):
>>>   File
>>> "C:\OSGEO4~1\apps\grass\grass-7.3.svn/scripts/m.proj.py
>>> <http://m.proj.py>",
>>> line 308, in
>> <module>
>>>     main()
>>>   File
>>> line 243, in main
>>>     inf = file(infile)
>>> IOError: [Errno 13] Permission denied: 'c:\\users\\cb2dd\\ap
>>> pdata\\local\\temp\\grass7-cb2dd-10432\\tmpovmbzm'
>>> ERROR: cs2cs failed
>> IIUC, this means that the call to m.proj in r.tileset has failed:
>> Could someone try if m.proj works on Windows ?
> C:\>v.out.ascii bridges | m.proj -o input=-
> and
> m.proj -o input=D:\wd\testepsg\coor.txt
> 81d37'10.19915"W|36d35'10.7323"N|1.000
> 81d37'47.06273"W|36d35'1.19866"N|2.000
> 81d33'45.90899"W|36d34'47.26688"N|3.000
> works here with
> System Info
> GRASS version: 7.3.svn
> GRASS SVN revision: r71384
> Build date: 2017-08-11
> Build platform: x86_64-w64-mingw32
> GDAL: 2.2.1
> PROJ.4: 4.9.3
> GEOS: 3.5.0
> SQLite: 3.17.0
> Python: 2.7.5
> wxPython: 2.8.12.1
> Platform: Windows-8-6.2.9200 (OSGeo4W)
> maybe there is some issue with the temporary file as input for cs2cs, but I
> can't find where ...
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Inclusion-of-additional-files-with-add-on-tp5331342p5331585.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
