[GRASS-dev] [GRASS GIS] #3407: v.in.ogr fails to import ESRI Shapefile with empty attribute table cells
GRASS GIS trac at osgeo.org
Wed Aug 23 12:36:57 PDT 2017
  Reporter:  mikatt   |      Owner:  grass-dev@…
      Type:  defect   |     Status:  new
  Priority:  normal   |  Milestone:
 Component:  Default  |    Version:  7.2.1
Resolution:           |   Keywords:
       CPU:  x86-64   |   Platform:  Linux
Comment (by rouault):
 > In order to preserve backwards compatibility for other software
 packages, GRASS will need to use OGR_F_SetFieldNull() starting with GDAL
 2.2 if data export should not change.
 Yes that only affects GeoJSON based drivers and GML, that are the only
 ones that can translate differently unset and NULL in the format. Other
 drivers will translate in the same way a unset field or a null field.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3407#comment:8>
