[GRASS-dev] [GRASS GIS] #3411: testsuite: encoding error
GRASS GIS trac at osgeo.org
Thu Aug 31 01:51:19 PDT 2017
 Reporter:  mlennert            |      Owner:  grass-dev@…
     Type:  defect              |     Status:  new
 Priority:  normal              |  Milestone:  7.2.2
Component:  Tests               |    Version:  svn-releasebranch72
 Keywords:  testsuite encoding  |        CPU:  Unspecified
 Platform:  Unspecified         |
 Whenever a test fails in the testsuite, and the LANGUAGE is fr_BE, I get
 the following error message
   File "test_r_mapcalc.py", line 99, in test_seed_required
     self.assertModuleFail('r.mapcalc', expression='rand_x = rand(1, 200)')
   File "/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
 gnu/etc/python/grass/gunittest/case.py", line 1180, in assertModuleFail
     module.run()
 gnu/etc/python/grass/pygrass/modules/interface/module.py", line 769, in
 run
     self.wait()
 gnu/etc/python/grass/pygrass/modules/interface/module.py", line 790, in
 wait
     module=self.name, errors=stderr)
 gnu/etc/python/grass/exceptions/__init__.py", line 71, in __init__
     msg += _(". See the following errors:\n%s") % errors
 UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 37:
 ordinal not in range(128)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3411>
