[GRASS-dev] Installing GRASS GIS on Windows
Jerry Huang jhuang37050 at gmail.com
Mon Dec 4 17:56:29 PST 2017
Okay I switched to a terminal with gcc and ran ./configure again. This time
I get the following error:
loading site script /mingw64/etc/config.site
/mingw64/etc/config.site: line 13: config.site:13: default build_alias set
to x86_64-w64-mingw32: command not found
/mingw64/etc/config.site: line 20: config.site:20: default prefix set to
/mingw64: No such file or directory
checking host system type... x86_64-pc-mingw64
checking for gcc... gcc
checking whether the C compiler (gcc  ) works... yes
checking whether the C compiler (gcc  ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for Cygwin environment... no
checking for mingw32 environment... yes
checking for executable suffix... .exe
checking for full floating-point support... yes
checking for pwd... /usr/bin/pwd
checking for source directory... /usr/src/grass72_release
checking for build directory... /usr/src/grass72_release
checking for svnversion... /usr/bin/svnversion
checking for MacOSX App... no
checking for MacOSX architectures... no
checking for MacOSX SDK... no
checking how to build libraries... shared
configure: error: ***Unknown platform: x86_64-pc-mingw64***
On Mon, Dec 4, 2017 at 8:01 PM, Jerry Huang <jhuang37050 at gmail.com> wrote:
> My package.log is linked below. Running configure by itself gives:
> loading site script /etc/config.site
> /etc/config.site: line 23: config.site:23: default build_alias set to
> x86_64-pc-msys: command not found
> /etc/config.site: line 30: config.site:30: default prefix set to /usr: No
> checking host system type... x86_64-pc-msys
> checking for gcc... no
> checking for cc... no
> configure: error: no acceptable cc found in $PATH
> On Sun, Dec 3, 2017 at 6:26 AM, Martin Landa <landa.martin at gmail.com>
> wrote:
>> Hi,
>> > OSGEO4W_POSTFIX=64 ./mswindows/osgeo4w/package.sh
>> > Checking package.log, it seems that the error stems from the absence of
>> a
>> > Platform.make file. Does anyone know a fix to this?
>> please post here full log file. Ma
>> Martin Landa
>> http://geo.fsv.cvut.cz/gwiki/Landa
>> http://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171204/1f5bd5a8/attachment.html>
