[GRASS-dev] [GRASS-PSC] GRASS add-on sharing and write access
Markus Metz markus.metz.giswork at gmail.com
Tue Dec 19 14:05:07 PST 2017
On Mon, Dec 18, 2017 at 9:21 AM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> [CC'ing grass-dev where such discussion should be happening]
> On 17/12/17 22:37, Markus Neteler wrote:
>> On Sun, Dec 17, 2017 at 9:14 PM, Markus Metz
>> <markus.metz.giswork at gmail.com> wrote:
>>> Right now, r.drain is somewhat overloaded: it creates directions for a
DEM
>>> same way r.fill.dir does it, or it uses supplied directions, then the
module
>>> extracts least costly paths. I suggest to have a new module r.path that
>>> extracts extract least costly paths from input directions and start
points
>>> and mark r.drain as deprecated.
>> Sounds interesting! At time it is a bit confusing.
> +1
See new ticket #3468
https://trac.osgeo.org/grass/ticket/3468
Markus M
> Moritz
> grass-psc mailing list
> grass-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-psc
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171219/6c255d69/attachment.html>
