[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#1898 (master - 7fa0125)
Vaclav Petras wenzeslaus at gmail.com
Mon Feb 6 06:50:24 PST 2017
On Mon, Feb 6, 2017 at 8:50 AM, Markus Neteler <neteler at osgeo.org> wrote:
> > Otherwise, there is no problem at all with using the git repo.
> Perhaps yes if that brings back the Mac tests at lowest cost
Assuming that the Homebrew repo will be tested separately, the question is
if we want to bring in another dependency - OSGeo Subversion to GitHub sync
- or if we want to keep dependencies to minimum. For now, getting code from
GitHub is the only way it works because of the broken SSL certificates, so
sure we can use it, but that's for now.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170206/f60bd549/attachment-0001.html>
