[GRASS-dev] v.in.osm
Štěpán Turek stepan.turek at seznam.cz
Thu Feb 9 14:34:10 PST 2017
I incline to clean up the data as a default. The module should behave in a
user-friendly way therefore expected behavior should be the default one.
I guess that most users would expect to import the data in topologically
correct format. If the topology is wrong, a user can get totally misleading
results (wrongly assuming they are correct) from various vector modules
which is not very nice.
Stepan
---------- Původní zpráva ----------
Od: Moritz Lennert <mlennert at club.worldonline.be>
Komu: Luca Delucchi <lucadeluge at gmail.com>, GRASS-dev <grass-dev at lists.
osgeo.org>
Datum: 9. 2. 2017 13:47:49
Předmět: Re: [GRASS-dev] v.in.osm
"On 09/02/17 10:20, Luca Delucchi wrote:
> Hi,
> I did a change in v.in.osm adding a c flag to cleanup the data and
> create a GRASS GIS network topological correct, this is done by
> default now. I attached a diff.
> The flag could be also the opposite, so don't cleanup the data.
> What do you think?
I would not make it the default. You cannot be sure that users want to
clean in the same way you do, so better to provide it as an
(well-documented) option.
Moritz
grass-dev mailing list
grass-dev at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev"
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170209/e4a36857/attachment.html>
